Bug Data Bridge pageNum
Thread begun 5/05/2021 3:03 am by Jonas | Last modified 5/06/2021 8:14 am by Ray Borduin | 1407 views | 3 replies |
Jonas
Explanation
I have created a detail page and results page through data bridge (latest version). This is a simple test. The results page has the layout type: Public. The only thing that is connected to the database is the title. I have chosen to link the title so you can choose to either press it or use the magnifying glass symbol to get to the detail page. Two pages are displayed with 20 repeats.
The problem
When you get to the detail page and then press "Back To Results", the product and the page it is on should be displayed on the results page. This works exactly as it should if you press the magnifying glass symbol. But something strange happens in the link. It is not generated correctly. The title text starts with "& pageNum _..." and does not work properly. That is, it does not go back to the correct page on the results page.
The reason I use DataAssist for this is to create code that I know is coded correctly. But if it is a bug, then of course this is not good.
Have you already fixed this? I tested the page and it seems to be working correctly.
I see... I had to browse to the second page of results to see the issue.
I think you can just remove this code on line 159 of the results page:
<?php echo(isset($_GET["pageNum_WADAbucBuckets"])?"&pageNum_WADAbucBuckets=".intval($_GET["pageNum_WADAbucBuckets"]):""); ?>
Technically I think that code should be part of the link instead of displayed. So this:
<a href="buckets_detail.php?buc_id=<?php echo($WADAbucBuckets->getColumnVal("buc_id")); ?>" ><?php echo(isset($_GET["pageNum_WADAbucBuckets"])?"&pageNum_WADAbucBuckets=".intval($_GET["pageNum_WADAbucBuckets"]):""); ?>
echo($WADAbucBuckets->getColumnVal("buc_name")); ?></a>
Should be:
<a href="buckets_detail.php?buc_id=<?php echo($WADAbucBuckets->getColumnVal("buc_id")); ?><?php echo(isset($_GET["pageNum_WADAbucBuckets"])?"&pageNum_WADAbucBuckets=".intval($_GET["pageNum_WADAbucBuckets"]):""); ?>" >
<?php echo($WADAbucBuckets->getColumnVal("buc_name")); ?></a>
Jonas
Thanks Ray, it works. One question: Was there a bug in DataAssist? Have you been able to reproduce the problem? It would be good to know if this problem will occur every time I use DataAssist?
It looks like DataAssist is putting that code in the wrong spot when you add a link through the wizard. I'll have to take a look and get it resolved in an upcoming build.
