Using SUM on Update
Thread begun 5/04/2021 11:11 am by dhagood355349 | Last modified 5/05/2021 8:45 am by Ray Borduin | 1525 views | 4 replies |
dhagood355349
Using SUM on Update
I'm sure this is covered somewhere in the forum. I want to take the sum of two values from two columns (SQL) from 1 id and update another column on Update from a webassist update page.
The two values would be the SUM of Day1_TotalWeight and Day2_TotalWeight to update Final_Weight
Thanks in advance!!!
$WADAAFTDirResult_update = new WA_MySQLi_RS("WADAAFTDirResult_update",$XXXXX,1);
$WADAAFTDirResult_update->setQuery("SELECT id, EventID, DQ, FullName, MemberID, Day2_Fish, Day2_Alive, Day2_Short, Day2_Penalty, Day2_BigBass, Day2_ScaleWeight, Day1_TotalWeight, Day2_TotalWeight, Points, Payout, Payout_Description FROM AFTDirResult WHERE AFTDirResult.id = ?");
$WADAAFTDirResult_update->bindParam("i", "".($_GET['id']) ."", "-1"); //Paramid
$WADAAFTDirResult_update->execute();
if (isset($_POST["Update"]) || isset($_POST["Update_x"])) {
$UpdateQuery = new WA_MySQLi_Query($XXXXX);
$UpdateQuery->Action = "update";
$UpdateQuery->Table = "AFTDirResult";
$UpdateQuery->bindColumn("DQ", "s", "".((isset($_POST["DQ"]))?$_POST["DQ"]:"") ."", "WA_BLANK");
$UpdateQuery->bindColumn("Day2_Fish", "d", "".((isset($_POST["Day2_Fish"]))?$_POST["Day2_Fish"]:"") ."", "WA_ZERO");
$UpdateQuery->bindColumn("Day2_Alive", "d", "".((isset($_POST["Day2_Alive"]))?$_POST["Day2_Alive"]:"") ."", "WA_ZERO");
$UpdateQuery->bindColumn("Day2_Short", "d", "".((isset($_POST["Day2_Short"]))?$_POST["Day2_Short"]:"") ."", "WA_ZERO");
$UpdateQuery->bindColumn("Day2_Penalty", "d", "".((isset($_POST["Day2_Penalty"]))?$_POST["Day2_Penalty"]:"") ."", "WA_ZERO");
$UpdateQuery->bindColumn("Day2_BigBass", "d", "".((isset($_POST["Day2_BigBass"]))?$_POST["Day2_BigBass"]:"") ."", "WA_ZERO");
$UpdateQuery->bindColumn("Day2_ScaleWeight", "d", "".((isset($_POST["Day2_ScaleWeight"]))?$_POST["Day2_ScaleWeight"]:"") ."", "WA_ZERO");
$UpdateQuery->bindColumn("Day2_TotalWeight", "d", "".((isset($_POST["Day2_TotalWeight"]))?$_POST["Day2_TotalWeight"]:"") ."", "WA_ZERO");
$UpdateQuery->bindColumn("Points", "d", "".((isset($_POST["Points"]))?$_POST["Points"]:"") ."", "WA_ZERO");
$UpdateQuery->bindColumn("Payout", "d", "".((isset($_POST["Payout"]))?$_POST["Payout"]:"") ."", "WA_ZERO");
$UpdateQuery->bindColumn("Payout_Description", "s", "".((isset($_POST["Payout_Description"]))?$_POST["Payout_Description"]:"") ."", "WA_BLANK");
$UpdateQuery->addFilter("id", "=", "d", "".((isset($_POST["WADAUpdateRecordID"]))?$_POST["WADAUpdateRecordID"]:"") ."");
$UpdateQuery->execute();
$UpdateGoTo = "ResultD2_detail.php?id=".((isset($_POST["WADAUpdateRecordID"]))?$_POST["WADAUpdateRecordID"]:"") ."".(isset($_GET["pageNum_WADAAFTDirResult"])?"&pageNum_WADAAFTDirResult=".intval($_GET["pageNum_WADAAFTDirResult"]):"") ."";
if (function_exists("rel2abs")) $UpdateGoTo = $UpdateGoTo?rel2abs($UpdateGoTo,dirname(__FILE__)):"";
$UpdateQuery->redirect($UpdateGoTo);
$UpdateQuery->bindColumn("Final_Weight", "d", "".($_POST["Day2_TotalWeight"] + $WADAAFTDirResult_update->getColumnVal("Day1_TotalWeight")) ."", "WA_ZERO");
dhagood355349
Using SUM on Update
Update - You're Awesome Ray!!
dhagood355349
Using SUM on Detail
Hey Ray, so can you do the same kind of function when the detail page comes up and executes? Have it execute another mathematic function?
I want to run two math functions, and it will only run one on Update (first one if finds), is there a way to add an additional or can it be done when the detail page executes?
Thanks in advance!
You can do math whenever you want on whichever page you want.
