PHP 8 support
Thread begun 5/03/2021 8:14 am by mlowe4 | Last modified 5/06/2021 8:19 am by Ray Borduin | 1570 views | 5 replies |
mlowe4
PHP 8 support
Does data bridge v2 support PHP 8 yet or is it still in development
thanks
Michael
I've made updates for php8, so it should be all working now. I use php8 locally and haven't run into any issues lately.
mlowe4
Great thanks
mlowe4
Found a couple of errors extension gd2 for PHP has been renamed to just gd in PHP 8 which seems to be affecting CAPTCHA images, also creating alternative connections to the database causes a "There's an error in your SQL code" error
The renaming of GD shouldn't effect the captcha functionality. Perhaps you don't have GD installed in your php8 version? I think it is disabled by default and has to be enabled in the php.ini file.
The connection error is most likely not related to your php version either. Did you install the latest version of the extension? I did make some php8 fixes a couple of weeks back.
mlowe4
Thanks got it sorted by downloading the most recent version of data bridge
Thanks for the updates much appreciated
Michael
