Delete web account
Thread begun 4/30/2021 6:17 am by Jonas | Last modified 5/03/2021 3:35 pm by Ray Borduin | 1999 views | 5 replies |
Jonas
Delete web account
I am creating a page where the user can choose to delete their entire user account.
The page first shows a summary of what will be deleted. When the user presses the delete button, a warning will appear in a "deleteBox" as usual. And when the user confirms this, the idea is that all data that the user has added to the database is deleted.
To do this, I think I have to:
#1, create multiple record sets that are linked to each table ID and filtered on SESSION ['SecurityAssist_UserID'].
#2, create the same number of hidden input fields, which are connected to each recordset.
#3, create delete record associated with each hidden input.
Since one of the tables contains data about uploaded images, I also have to use the "Delete File" function.
I have created this, but what happens is that only the first record from each recordset is deleted. I guess I need to create a repeat function, but how do I do this?
Usually you can set up the delete record server behavior to be based on the users ID and not use a separate recordset at all. The delete record server behavior will delete multiple records if you use a key that isn't unique like the userID.
So for instance... your first delete wouldn't be:
$DeleteQuery->Table = "bucGrade";
$DeleteQuery->addFilter("gra_ID", "=", "i", "".((isset($_POST["WADADeleteMygradesID"]))?$_POST["WADADeleteMygradesID"]:"") ."");
it would be:
$DeleteQuery->addFilter("gra_userID", "=", "i", "".($_SESSION['SecurityAssist_UserID']) ."");
Then you don't need any recordsets or hidden fields at all.
Jonas
Nice, it works now. All user data is deleted from all tables as you describe. Thanks!
But what do I do with images uploaded by the user. I want them to be deleted as well. When the images are uploaded, they are named as follows: bucID + userID, for example "buc-11_user-2.jpg". They are placed in two folders. One high resolution and one low resolution.
When I'm doing user specific files, I usually save them in a user specific folder, so they are easy to delete. In your case, you would probably want to use a recordset and loop through it deleting the images before deleting from the table.
Jonas
I have already done this recordset:
$rsDeleteMyimages = new WA_MySQLi_RS("rsDeleteMyimages",$bucketlistDB,0);
$rsDeleteMyimages->setQuery("SELECT bucImages.* FROM bucImages WHERE bucImages.ima_usrID = ?");
$rsDeleteMyimages->bindParam("i", "".$_SESSION['SecurityAssist_UserID'] ."", "-1"); //WAQB_Param1
$rsDeleteMyimages->execute();?>
But I don't know how to loop it?
Put a repeat region on the page for the recordset for all records... then just copy and paste it around the delete file code instead.
