Hi Ray, In Dreamweaver I have lost access to the tables on my web host's server. I have using the tables for 6 months with no problem. I can connect to the webhost server's database but am not seeing tables. I did see the tables yesterday.
Thread begun 4/24/2021 7:59 am by p03976803142 | Last modified 4/26/2021 5:04 pm by Ray Borduin | 1038 views | 2 replies |
p03976803142
In Dreamweaver CC 2020 and under the Webassist tab, I open a new recordset. I go to the Connection (NYPavConn in my case), Edit Connection, click on Test, and Dreamweaver reports the "Connection was made successfully". However when I attempt to create a recordset using the same connection, Dreamweaver reports "No Table Found". For the past 6 months, the tables were found and opened properly. Today something changed.
Need your help!!
Thanx
Ernie Papadoulias
You probably started forcing https:// and don't have https:// in your testing server url in your Dreamweaver site definition.
p03976803142
Problem Solved
The solution was to ignore Dreamweaver 2020 and to get Webassist installed (with Ray's help) on Dreamweaver 2021. It appears to me that the Adobe transition from 2020 to 2021 had something to do with my problem. After Webassist installation, Dreamweaver 2021 is working fine.
Thanx, Ray
