Advanced Options errors
Thread begun 4/23/2021 8:26 am by Patrice | Last modified 4/26/2021 5:04 pm by Ray Borduin | 4951 views | 22 replies |
PatriceWebAssist
I am trying to add a size option with a different pricing structure to a product. I keep the box checked for changing per size, changing the cost but the save delivers an error of:
Update ps4_products set ProductPrice = '65', ProductUpdateDate = '2021-04-23 15:11:18' WHERE ProductID in ( select Distinct ProductID from ps4_productoptions where ps4_productoptions.OptionID in ('') AND ProductID in (select ProductID from ps4_productoptions where OptionID = 30)) OR ProductID = 33
Truncated incorrect DOUBLE value: ''
Any thoughts on what to look for?
That part is wrong... it isn't getting the optionID set correctly.
PatriceWebAssist
So what should I do to fix?
I'd have to look a the code. Do you have a url I can look at? I'd need FTP access.
PatriceWebAssist
yes, thanks
PatriceWebAssist
more details
The FTP information isn't working for me. Please check it and make sure it is all correct.
Actually I got it to work... I must have copied the password wrong with a space at the end.
PatriceWebAssist
thanks
also there was an autocorrect space in user...
thanks for looking at it for me
holler when I can retest...
Much thanks
I have fixed this issue. Please try again and let me know if you run into anything else.
