Search does work for dropdown
Thread begun 4/11/2021 12:44 am by rogersds267040 | Last modified 4/15/2021 5:58 am by Ray Borduin | 651 views | 2 replies |
rogersds267040
I created a search on my result page. The text box search works.
The dropdowns don't work. I get the following "There is an error in your SQL syntax."
Results on my page works fine but not with the search.
Open the rsobj.php file and turn debug from false to true. That should give you a better error message. It is probably a data type mismatch.
rogersds267040
Thank you.
The joins my query wasn't handled properly with the search plugin.
