Update with Bootstrap 4 modal
Thread begun 4/08/2021 10:46 pm by Raza | Last modified 4/19/2021 7:54 am by Ray Borduin | 2477 views | 7 replies |
Raza
Hello Ray
how are you doing? I want to ask that how to add Update Server Behavior in Bootstrap 4 modal? I am attaching files
Bootstrap is a design framework. It shouldn’t effect how the update is applied and works. You just create a form and apply the update server behavior.
I’d probably use the databridge page generator and add it to your page (bootstrap or otherwise) with a plug-in to keep my functionality and design compartmentalized.
Raza
but its not working on my side I have done as you said but it not update
I'd have to look at the page that isn't working... Most likely it doesn't have anything to do with bootstrap.
Raza
what I should do now?
You commented out this code on line 29:
//$UpdateQuery->addFilter("id", "=", "i", "".($_GET['id']) ."");
That is the code that identifies the record to be updated. The update won't work without that row.
Raza
I have already removed comment but still not working
I'd have to debug this live. Can I get FTP access and a url I can use to reproduce the issue?
