Password strength requirement not met
Thread begun 4/06/2021 1:23 pm by Jonas | Last modified 4/08/2021 11:03 am by Ray Borduin | 1749 views | 5 replies |
Jonas
I have created Security Assist Pages from the menu which I have changed some details in. But it does not accept password. What is the problem?
Here is the URL: http://jonasn.se/adminTst/admin/registration.php
There is validation set with a number of numbers and letters and capitalization requirements. If you attach the file I can show you where and explain how to change them.
Jonas
I apologize. But I have written a post in another post that it is better if you look at. I forgot I wrote this here.
Please look here: http://www.webassist.com/forums/posts.php?pid=231193, then u can delete this if u want.
This looks like a separate issue. One is with the validation not letting you use simple passwords, and the other post is about creating different user groups for different page access. I'll try to help you with the other one as well. This one is about updating the server validation and possible pattern attribute in the client validation to allow more simple passwords, or just updating the error message to be more specific about what is required like: "passwords must include upper case and lower case characters and at least 1 number"
Jonas
That's right, I'm confusing it.
It looks like the only requirement is that the password must be at least 6 characters in length. You can just update the error message to say that specifically instead of the generic message you see now, or you could remove or reduce that requirement in the server validation server behavior or manually on line 19. The "6,500" part means between 6 and 500 characters in length.
