Parse error: syntax error, unexpected '{' on line 1
Thread begun 4/03/2021 9:15 am by Daryl | Last modified 4/04/2021 10:12 am by Ray Borduin | 3066 views | 9 replies |
DarylBeta Tester
I have an old site using Framework Builder, I have only updated some text in a file that is a plugin and have uploaded it to find the site now gets the above error.
I have tried loading the individual included files and have found that the error exists on files that have a database connection in a folder called Connections.
It is a MySQL connection, the PHP version is 5.6. The site was working OK until I updated an unrelated included file however.
and also on non database driven pages that have the following in line 1 and 3
<?php require_once('../webassist/framework/framework.php'); ?>
<?php require_once('../webassist/framework/library.php'); ?>
The error message should include a file name.
I'd have to see the files involved to comment on how to fix it. Can I get FTP access? It sounds like it might be an issue with the connection file. Maybe you can attach that? If you attach the files involved and give the full error message I might be able to figure it out without ftp access.
DarylBeta Tester
Hi Ray
I have added details below, the error says its line 1 of index.php but that is the framework.php file.
I have been having issues with the extensions putting the code in unusual places and also with dreamweaver seeming to remove the first column of characters when I open them so I have been trying to resolve some of these issues manually.
I have opened all the included files in Sublime text but am unable to find any unmatched curly braces.
I downloaded your index.php file and all of the line breaks were removed. The entire file was on line 1.
I added line breaks back including changing things like: <?phpif
I now get the same error on another file. I'm thinking this might be an issue in a lot of files on your site.
That is what was causing the issue. I'm not sure what removed all of the line breaks. What are you using to upload the files? The issue was the corrupted index file.
My only guess is that the FTP program you are using is removing the line breaks.
DarylBeta Tester
Thanks Ray
Thats interesting and would explain the error code.
I am using Dreamweaver for FTP upload of files.
When I view the files locally they appear to be normal but have also had to manually correct some code like there <?phpif that you have mentioned
The files look OK if accessed directly from channel as well
If you go to Preferences in dreamweaver and look at Code Format, what is selected as the "Line Break Type"?
DarylBeta Tester
CR LF (Windows)
Should this be CR (Macintosh) as I am on Mac?
This is something that I have never needed to change before
CR LF should work. It includes both, so usually if anything that could cause double line breaks. Maybe try restarting Dreamweaver or try a different FTP program and see if that helps. You could try different line break settings. Maybe even changing to another one and back would work. Something is causing DW to remove them, but I've honestly never seen that before.
DarylBeta Tester
I have changed to CR Mac and re-downloaded the index.php from the server and now everything is bunched up into 7 lines
That is the problem... yeah I wouldn't download the files. The files are messed up online, your local copy was the good one. I can't tell you what the issue is causing it. You may need to go back and add the line breaks manually at this point.
