Problems with User Login, etc
Thread begun 4/02/2021 10:14 am by yogastudents362523 | Last modified 8/27/2024 5:48 pm by vjera | 2574 views | 9 replies |
yogastudents362523
Hi
Hoping you are well.
”Fatal error: Cannot declare class WA_MySQLi_RS, because the name is already in use in /var/www/vhosts/kofibusia.com/httpdocs/webassist/mysqli/rsobj.php on line 3”
Unfortunately, one of my users has just reported the above error when trying to log in to check her specs and data:in the PowerMessenger database.
I am hoping it is something simple, stupid, & inadvertently ridiculous I have done while being in a hurry to catch up while recuperating.
Thank you,
KB
I'd need FTP access, or at least an attached copy of the page that users_login.php page. It sounds like there is more than one reference to the rsobj.php file on the page and you probably just have to delete one.
yogastudents362523
Responded in other ticket, same details in private area, thank you, KB
For some reason your server isn't respecting the require_once() command and it is adding the file more than once. I resolved the problem by deleting the references to rsobj.php and queryobj.php from the users_profile.php page since it is already added by the theme file at the top of the page.
yogastudents362523
Thank you,
That now seems to be working.
I do not know what happened to the server in the 2 months or so I was indisposed and not using it.
But my thanks again,
KB
yogastudents362523
Can you recollect which files (that you changed) I should now download to keep as backups?
Sorry to have only just thought of it.
Thank you,
KB
Just the users_profile.php page.
yogastudents362523
Thank you.
KB
pinklipservice
Meet top vadodara service
This post has been deleted.
