t get value both Inch Marks & Feet Marks go into database without error
Thread begun 3/26/2021 1:36 pm by lr_leal239405 | Last modified 3/29/2021 11:06 am by Ray Borduin | 1705 views | 3 replies |
lr_leal239405
I have a value from our database that has to be inserted into another table when it's selected from a dropdown. I get 'syntax error' upon submitting to enter. It is this: 2.5" Flexible neoprene composite duct, 25' bulk length
When I take off the feet mark from 25', it works fine. I've tried the following:
$myvalue = addslashes($WADAcac_prod_subcategory_leveltwo_NEW_insertx->getColumnVal('prod_name');
$myvalue = str_replace("'", '",$WADAcac_prod_subcategory_leveltwo_NEW_insertx->getColumnVal('prod_name');
$myvalue = str_replace("'", "ft",$WADAcac_prod_subcategory_leveltwo_NEW_insertx->getColumnVal('prod_name');
$myvalue = str_replace("'", "ft",addslashes($WADAcac_prod_subcategory_leveltwo_NEW_insertx->getColumnVal('prod_name'));
$myvalue = addslashes(str_replace("'", "ft",$WADAcac_prod_subcategory_leveltwo_NEW_insertx->getColumnVal('prod_name'));
and many other ways. On top of that, this is from a call to an AJAX function that replaces the code, which works fine, but not sure if that has anything to do with it. The exact code right now is in a do while (all works fine as long as I take off the single quote mark).
Attached is the file that is called using AJAX. Line 102.
Can you help with this? Thanks.
Thanks.
What happens when you use:
<select name="prod_namedd" id="prod_namedd" tabindex="10" onChange="getPrice(this.value)" autocomplete="on">
            <option value="" selected>-Select-</option>
$wa_startindex
= 0;
while(!
$WADAcac_prod_subcategory_leveltwo_NEW_insertx->atEnd()) {
$wa_startindex = $WADAcac_prod_subcategory_leveltwo_NEW_insertx->Index;
        <option value="<?php echo(!empty($WADAcac_prod_subcategory_leveltwo_NEW_insertx->getColumnVal('prod_name')))?$WADAcac_prod_subcategory_leveltwo_NEW_insertx->getColumnVal('prod_name'):$WADAcac_prod_subcategory_leveltwo_NEW_insertx->getColumnVal('prod_name2'); ?>"><?php echo($WADAcac_prod_subcategory_leveltwo_NEW_insertx->getColumnVal('prod_name')); ?><?php echo($WADAcac_prod_subcategory_leveltwo_NEW_insertx->getColumnVal('prod_name2')); ?></option>
->moveNext();
$WADAcac_prod_subcategory_leveltwo_NEW_insertx->moveFirst(); //return RS to first record
unset($wa_startindex);
unset(
$wa_repeatcount);
    </select>
lr_leal239405
Thanks for your help. I still get a syntax error after replacing with your code because of the single quote mark.
I had this originally:
echo "<option value='" . ((!empty($WADAcac_prod_subcategory_leveltwo_NEW_insertx->getColumnVal('prod_name')))?html_entity_decode($WADAcac_prod_subcategory_leveltwo_NEW_insertx->getColumnVal('prod_name')):html_entity_decode($WADAcac_prod_subcategory_leveltwo_NEW_insertx->getColumnVal('prod_name2'))) . "' " . "selected>";
echo html_entity_decode($WADAcac_prod_subcategory_leveltwo_NEW_insertx->getColumnVal('prod_name')) . html_entity_decode($WADAcac_prod_subcategory_leveltwo_NEW_insertx->getColumnVal('prod_name2')) ;
echo "</option>";
lr_leal239405
UPDATE - I didn't get that one set of code to work but I worked around it by replacing the data in the original table it's pulling from with
&apos;
instead of the feet mark '
2.5" Flexible neoprene composite duct, 25&apos; bulk length
