Sending query like array with coma separated to URL and echo the selected checkbox
Thread begun 3/21/2021 8:55 am by Rokon | Last modified 3/24/2021 8:04 pm by Ray Borduin | 3399 views | 8 replies |
Rokon
Hello
I am having a problem to send coma separated value to url which is like as below;
I have created a repeat region where all the books names shows in separate checkbox, after that i select some random book by selecting the checkbox and after submit the value for search it shows url like book=3&book=20&book=8 and for this only the result comes from one book only and not from all the books but if i can send the query like book=3,20,8 then I get the results from all the books.
Also I need to echo back the selected checkbox which I selected before passing the query so that I know which books I selected.
The example live page is
https://www.hadithbd.com/hadith/search/filter/?q=%E0%A6%86%E0%A6%A6%E0%A6%AE&book=3&book=20&book=8&lang=bn&WADbSearch1=
Please help. I am sending the login info in the PM
To send multiple books, the url would be: https://www.hadithbd.com/hadith/search/filter/?q=%E0%A6%86%E0%A6%A6%E0%A6%AE&book[]=3&book[]=20&book[]=8&lang=bn&WADbSearch1=
you have to add the [] to allow it to be an array and pass multiple values.
Rokon
Hello Ray
I tried like that but seems somewhere I am doing something wrong and for this reason now I don't get any result.
$SearchPage = new WA_MySQLi_RS("SearchPage",$hadithbd,20);
$SearchPage->setQuery("SELECT hadithmain.HadithID, hadithmain.BookID, hadithmain.SectionID, hadithmain.HadithNo, hadithmain.hadithNo2, hadithmain.hadithNo3, hadithmain.ArabicHadith, hadithmain.ArabicHadithNew, hadithmain.BanglaHadith, hadithmain.EnglishHadith, hadithmain.HadithNote, hadithbook.BookNameBD, hadithchapter.ChapterBG, hadithchapter.ChapterAR, hadithchapter.ChapterEN, hadithexplanation.explanation, hadithstatus.StatusBG, hadithsection.SectionBD, hadithsection.SectionEN FROM hadithmain LEFT OUTER JOIN hadithbook ON hadithmain.BookID = hadithbook.BookID LEFT OUTER JOIN hadithchapter ON hadithmain.chapterID = hadithchapter.chapID LEFT OUTER JOIN hadithexplanation ON hadithmain.HadithID = hadithexplanation.hadithID LEFT OUTER JOIN hadithstatus ON hadithmain.HadithStatus = hadithstatus.StatusID LEFT OUTER JOIN hadithsection ON hadithmain.SectionID = hadithsection.SectionID WHERE hadithmain.HadithActive = 1 AND hadithmain.BookID IN (?)");
$SearchPage->bindParam("il", "".(isset($_GET['book[]'])?$_GET['book[]']:"") ."", "-1"); //WAQB_Param1
$SearchPage->execute();?>
<div class="form-check">
$wa_startindex = 0;
while(!$booksList->atEnd()) {
$wa_startindex = $booksList->Index;
<label class="form-check-label pl-3">
<input name="book[]" type="checkbox" class="form-check-input" value="<?php echo($booksList->getColumnVal("BookID")); ?>"><?php echo($booksList->getColumnVal("BookNameBD")); ?>
</label>
$booksList->moveNext();
$booksList->moveFirst(); //return RS to first record
unset($wa_startindex);
unset($wa_repeatcount);
</div>
You have to turn the array back into a comma separated string in the recordset like:
$SearchPage->bindParam("il", "".(isset($_GET['book'])?implode(","$_GET['book']):"") ."", "-1"); //WAQB_Param1
Rokon
it shows some error and I think it should be like as below;
$SearchPage->bindParam("il", "".(isset($_GET['book'])?implode(",",$_GET['book']):"") ."", "-1"); //WAQB_Param1
Meanwhile just little more help needed to echo back the checked status that means shows back which books I was selected for the query on below code
How can you tell which ones were checked? Is this on the results page? I need context. Where could I get the previously selected checkboxes? $_GET?
Rokon
Dear Ray
I made one separate post on this subject though. This is on the same result page on a form and pls see below the code
<form name="searchForm" action="/hadith/search/filter/" method="GET" accept-charset="UTF-8">
<div class="form-row">
<div class="col-md-6 col-sm-12 my-1">
<input class="form-control" type="text" name="q" value="<?php echo ((isset($_GET["q"]))?$_GET["q"]:""); ?>" placeholder="যে শব্দ দিয়ে খুঁজতে চান..." required>
</div>
<div class="col-auto my-1">
<select name="lang" id="lang" class="custom-select mr-sm-2" required>
<option value="">-ভাষা সিলেক্ট-</option>
<option value="bn" <?php if (!(strcmp("bn", ((isset($_GET["lang"]))?$_GET["lang"]:"")))) {echo "selected=\"selected\"";} ?>>শুধু বাংলা</option>
<option value="en" <?php if (!(strcmp("en", ((isset($_GET["lang"]))?$_GET["lang"]:"")))) {echo "selected=\"selected\"";} ?>>English only</option>
<option value="ar" <?php if (!(strcmp("ar", ((isset($_GET["lang"]))?$_GET["lang"]:"")))) {echo "selected=\"selected\"";} ?>>العربية</option>
<option value="all"<?php if (!(strcmp("all", ((isset($_GET["lang"]))?$_GET["lang"]:"")))) {echo "selected=\"selected\"";} ?>>বাংলা/العربية</option>
</select>
</div>
<div class="custom-control custom-checkbox mr-sm-2">
<input type="checkbox" class="custom-control-input" id="customControlAutosizing" name="exact" value="1" <?php if (!(strcmp(((isset($_GET["exact"]))?$_GET["exact"]:""),1))) {echo "checked=\"checked\"";} ?>>
<label class="custom-control-label" for="customControlAutosizing">হুবহু শব্দে</label>
</div>
</div>
<script language="JavaScript">
function toggle(source) {
checkboxes = document.getElementsByName('book[]');
for(var i=0, n=checkboxes.length;i<n;i++) {
checkboxes[i].checked = source.checked;
</script>
<div class="form-check pl-3">
<input type="checkbox" onClick="toggle(this)" /><span class="text-danger"> সব বই সিলেক্ট করুন</span>
</div>
$wa_startindex = 0;
</label>
</div>
</div>
<div class="col mb-2 my-1">
<button type="submit" name="WADbSearch1" class="btn btn-dark btn-block"><i class="fas fa-search"></i> খুঁজুন</button>
</div>
</div>
</form>
I think this would work then:
<input name="book[]" type="checkbox" class="form-check-input" <?php echo(in_array($booksList->getColumnVal("BookID"),isset($_GET["book"])?$_GET["book"]:array())?"checked":""); ?> value="<?php echo($booksList->getColumnVal("BookID")); ?>"><?php echo($booksList->getColumnVal("BookNameBD")); ?>
Rokon
Thanks Ray, It works as expected.
