Execute query not inserting
Thread begun 3/21/2021 7:13 am by Sweens | Last modified 3/22/2021 3:05 pm by Ray Borduin | 1312 views | 4 replies |
Sweens
Hi Ray
I'm trying to execute a query hen a button is pressed, but nothing happens; I've tested the query locally (using numbers instead of the parameters) and it works fine.
Any suggestions?
Cheers
Chris
Try adding debug code before:
$ExecuteQuery->execute();
so it has:
var_dump($ExecuteQuery);
die($ExecuteQuery->Statement);
That will give you a lot more information that might allow you to figure out what is wrong.
Sweens
Hi Ray
'This page isn't working' error after adding this.
Cheers
Chris
I had a typo:
var_dump($ExecuteQuery));
should be:
Sweens
Thanks Ray - all sorted now (I hadn't auto-incremented the PK field)
Cheers
Chris
