“Getting started with MySQLi Server Behaviours,” tutorial error.
I was working with Web development tutorial, “Getting started with MySQLi Server Behaviours.”
I stuck at the very beginning, at point “8. Click the Advanced button and then the Query Builder button to access the MySQLi Server Behaviours visual query building tool.”
When I click on Query Builder, I get the following message, “Error Inspecting SQL, • table not found: products, • order by column not found: ProductID. These values will be automatically removed the next time you use the visual editor or advanced tab to edit your SQL.”
However, test of the recordset was successful both in the Simple and Advanced screens (I was able to see data in the table).
I tried with other database, BlueSkyMusic, and I got the same error at the same point. So, I could not proceed. How should I solve the problem?
