STARTTLS in classic asp
Thread begun 3/16/2021 12:54 pm by sharon39426 | Last modified 3/22/2021 1:58 pm by Ray Borduin | 2591 views | 5 replies |
sharon39426
Hi. I have older versions of your extensions and none of them will install in the current version of Dreamweaver. I need to add STARTTLS to an email page using classic asp, but can't figure out how. If I upgrade to the latest versions, will I be able to add STARTTLS? My database is SQL Server--is that supported, or does everything have to be MySQLi (I have to use SQL Server). Do your current extensions use classic asp, or would I need to move to PHP? If the updated extensions can't help me, would someone be able to do this for me with one of your $99 support sessions? Thank you.
Dreamweaver and our extensions no longer work with classic asp.
I don't think they would help with STARTTLS anyway, that would have to be hand coded even if the extensions installed.
I could try to help in a $99 session. Do you have sample code for how to integrate STARTTLS?
sharon39426
All I found was Mail.TLS = True but no idea where to put it
<!--#include file="WA_Universal_Email/AspEmail_VB.asp" -->
function WA_Universal_Email_1_SendMail(RecipientEmail)
dim MailObject, MailAttachments, MailBCC, MailCC, MailTo, MailBodyFormat, MailBody, MailImportance, MailFrom, MailSubject
MailAttachments = ""
MailBCC = ""
MailCC = ""
MailTo = ""
MailBodyFormat = ""
MailBody = ""
MailImportance = ""
MailFrom = "TRAIN TRACK|WA|" & cStr((mailserver.Fields.Item("MailFrom").Value)) & ""
MailSubject = "Reset Password"
'Global Variables
gBodyFormat = ""
set WA_MailObject = WAUE_Definition("" & cStr((mailserver.Fields.Item("mailserver").Value)) & "","" & cStr((mailserver.Fields.Item("mailport").Value)) & "","" & cStr((mailserver.Fields.Item("mailuser").Value)) & "","" & cStr((mailserver.Fields.Item("mailpswd").Value)) & "")
if (RecipientEmail <> "") then
set WA_MailObject = WAUE_AddRecipient(WA_MailObject,RecipientEmail)
else
'To Entries
set WA_MailObject = WAUE_AddRecipient(WA_MailObject,"" & cStr((UserEmail.Fields.Item("Email").Value)) & "")
end if
'Attachment Entries
'BCC Entries
'CC Entries
'Character Set
'Body Format
set WA_MailObject = WAUE_BodyFormat(WA_MailObject,1)
MailBodyFormat = gBodyFormat
'Set Importance
set WA_MailObject = WAUE_SetImportance(WA_MailObject,"3")
'Start Mail Body
MailBody = MailBody & "Click the link to reset your password: http://"& cStr(Request.ServerVariables("HTTP_HOST")) & Left(cStr(Request.ServerVariables("URL")),(Len(cStr(Request.ServerVariables("URL")))-20)) & "UserNewPswd.asp?Hashpass=" & cstr((Recordset1.Fields.Item("HashPass")))& "&StaffID="&cstr((Recordset1.Fields.Item("staffid")))
'End Mail Body
set WA_MailObject = WAUE_SendMail(WA_MailObject,MailAttachments,MailBCC,MailCC,MailTo,MailImportance,MailFrom,MailSubject,MailBody)
set WA_MailObject = nothing
end function
I would love to fix this one issue, but then going forward it sounds like I need to move to PHP. Do your extensions work in Dreamweaver with PHP and SQL Server? Thank you
Please attach a copy of the page: WA_Universal_Email/AspEmail_VB.asp
I should be able to figure out what the correct syntax is by looking at that page.
sharon39426
dim gBodyFormat, gOneToAddress
gBodyFormat = ""
gOneToAddress = false
function WAUE_AddAttachment(mailObj,attPath)
if (WAUE_isAttachment(attPath)) then
mailObj.AddAttachment attPath
end if
set WAUE_AddAttachment = mailObj
end function
function WAUE_SetCharset(mailObj,charSet)
mailObj.CharSet = charSet
set WAUE_SetCharset = mailObj
end function
function WAUE_AddBCC(mailObj,bccEmail)
if (bccEmail <> "") then
emailArr = Split(cStr(bccEmail), ";")
for bcc=0 to UBound(emailArr)
if (InStr(cStr(emailArr(bcc)), "@")) then
emailArr2 = Split(cStr(emailArr(bcc)), "|WA|")
if (UBound(emailArr2) = 0) then
if (WAUE_isEmailAddress(emailArr(bcc))) then
mailObj.AddBCC WA_StripSpaces(cStr(emailArr(bcc)))
end if
else
if (InStr(emailArr2(1), "@")) then
if (WAUE_isEmailAddress(emailArr2(1))) then
mailObj.AddBCC WA_StripSpaces(emailArr2(1)), WA_TrimLeadingSpaces(emailArr2(0))
end if
else
if (WAUE_isEmailAddress(emailArr2(0))) then
mailObj.AddBCC WA_StripSpaces(emailArr2(0)), WA_TrimLeadingSpaces(emailArr2(1))
end if
end if
end if
end if
next
end if
set WAUE_AddBCC = mailObj
end function
function WAUE_AddCC(mailObj,ccEmail)
if (ccEmail <> "") then
emailArr = Split(cStr(ccEmail), ";")
for cc=0 to UBound(emailArr)
if (InStr(cStr(emailArr(cc)), "@")) then
emailArr2 = Split(cStr(emailArr(cc)), "|WA|")
if (WAUE_isEmailAddress(emailArr(cc))) then
mailObj.AddCC WA_StripSpaces(cStr(emailArr(cc)))
end if
else
mailObj.AddCC WA_StripSpaces(emailArr2(1)), WA_TrimLeadingSpaces(emailArr2(0))
end if
else
mailObj.AddCC WA_StripSpaces(emailArr2(0)), WA_TrimLeadingSpaces(emailArr2(1))
end if
end if
end if
end if
next
end if
set WAUE_AddCC = mailObj
end function
function WAUE_AddRecipient(mailObj,recEmail)
if (recEmail <> "") then
emailArr = Split(cStr(recEmail), ";")
for rec=0 to UBound(emailArr)
if (InStr(cStr(emailArr(rec)), "@")) then
emailArr2 = Split(cStr(emailArr(rec)), "|WA|")
if (WAUE_isEmailAddress(emailArr(rec))) then
mailObj.AddAddress WA_StripSpaces(cStr(emailArr(rec)))
gOneToAddress = true
end if
else
mailObj.AddAddress WA_StripSpaces(emailArr2(1)), WA_TrimLeadingSpaces(emailArr2(0))
end if
else
mailObj.AddAddress WA_StripSpaces(emailArr2(0)), WA_TrimLeadingSpaces(emailArr2(1))
end if
end if
end if
end if
next
end if
set WAUE_AddRecipient = mailObj
end function
function WAUE_BodyFormat(mailObj,bodyFormat)
if (bodyFormat = 0 OR bodyFormat = 2) then
mailObj.IsHTML = true
end if
gBodyFormat = bodyFormat
set WAUE_BodyFormat = mailObj
end function
function WAUE_Definition(remHost,port,login,pword)
set retVal = Server.CreateObject("Persits.MailSender")
retVal.Host = remHost
if (port <> "") then
retVal.Port = cInt(port)
end if
if (login <> "") then
retVal.UserName = login
retVal.Password = pword
end if
set WAUE_Definition = retVal
end function
function WAUE_SendMail(mailObj,mailAttachments,mailBCC,mailCC,mailTo,mailImportance,mailFrom,mailSubject,mailBody)
if (gOneToAddress) then
if (InStr(mailFrom, "|WA|")) then
dim mailFromArr
mailFromArr = Split(mailFrom, "|WA|")
for f=0 to UBound(mailFromArr)
if (InStr(cStr(mailFromArr(f)), "@")) then
mailObj.From = mailFromArr(f)
else
mailObj.FromName = mailFromArr(f)
end if
next
else
end if
if (gBodyFormat = 2) then
mailBodyArray = Split(mailBody, "<multipartbreak>")
mailBody = mailBodyArray(1)
mailObj.AltBody = mailBodyArray(0)
end if
mailObj.Body = mailBody
mailObj.Subject = mailSubject
mailObj.Send()
end if
set WAUE_SendMail = mailObj
end function
function WAUE_SetImportance(mailObj,Importance)
dim newPriority
newPriority = 3
if (NOT IsNumeric(Importance)) then
if (UCase(Importance) = "HIGH") then
newPriority = 1
end if
if (UCase(Importance) = "LOW") then
newPriority = 5
end if
else
newPriority = cInt(Importance)
end if
mailObj.Priority = newPriority
set WAUE_SetImportance = mailObj
end function%>
I think you can add it after this line:
like:
WA_MailObject.TLS = True
