An unidentified error has occurred
Thread begun 3/15/2021 12:23 pm by julesN | Last modified 5/17/2021 11:22 am by Ray Borduin | 2618 views | 9 replies |
julesN
I have my database set up and can't figure out why it won't connect. I am getting the error: An unidentified error has occurred
I'm pretty sure I have checked all my settings. I might have missed something?
www.vidasalonstavely.ca
Please help! :(
Usually this is an issue with your Site settings in Dreamweaver, specifically your Testing server, which is required to be configured properly in order to connect to the database.
julesN
OK, so I'm a little bit farther ahead. It seems to be connecting, however, I've given the user all permissions, and it says that the user needs "write" access, which has been given. Huh??? I have uploaded a screenshot.
Can you open and test the connection in the database panel without errors?
julesN
Yes... I have uploaded screenshots! Both MySQL and MySQLi
PowerCMS hasn't been updated to work with MySQLi connections yet. That is why you are getting the error.
julesN
I changed it to a MySQL connection, and it's still doing it. I also deleted the MySQLi connection off the server. See screenshot.
Please post a phone number in the private area and I can call you to set up screen sharing to look into this with you.
julesN
PMed you...
You would have to change the web URL setting to have https://
