Insert page getting "there is an error in your SQL syntax"
Thread begun 3/14/2021 11:53 am by Patrice | Last modified 3/16/2021 10:08 am by Ray Borduin | 2174 views | 5 replies |
PatriceWebAssist
I have 4 new admin pages: insert, update, detail and results. The insert page is throwing the error.
Sequence: I had an unilitizatio type error while working on a new set of admin, so uninstalled, reinstalled DA. (Turns out the solution was to delete autosave.xml file) I also uploaded a rsobj.php page as I know this has to be one saved on hd and not the one in uninstall/reinstall etc. This site's other admin pages are all fine.
Only the insert is throwing the issue. I did line 11 in rsobj file to true.
Since only Insert page is the issue, I am having a hard time finding how to fix. If update etc were failing, I'd just start over.
Any ideas, most welcome!
Change the debug value in queryobj.php and that should give you a better error.
PatriceWebAssist
change to what?
class WA_MySQLi_Query {
public function __construct($conn, $mrt = "mrt") {
$this->Action = "";
$this->UseAction = "";
$this->AffectedRows = 0;
$this->Connection = $conn;
$this->Debug = true;
$this->EncryptionAlgorithm = "blowfish";
$this->EncryptionKey = "Change Me";
$this->EncryptionMode = "cbc";
$this->Error = "";
$this->ErrorMessage = "There is an error in your SQL syntax.";
$this->ErrorNo = 0;
$this->FieldCount = 0;
$this->Filter = "";
$this->FilterValues = array();
$this->ID = 0;
$this->InsertID = 0;
$this->JavascriptRedirect = false;
$this->MRTField = $mrt;
$this->NumRows = 0;
$this->ParamColumns = array();
$this->ParamCount = 0;
$this->ParamDefaults = array();
$this->ParamTypes = array();
$this->ParamValues = array();
$this->Prepared = true;
$this->RelationalColumns = array();
$this->RelationalKeyColumn = false;
$this->RelationalRows = array();
$this->RelationalRowsFound = false;
$this->RepeatConditions = array();
$this->RepeatedParams = array();
$this->RepeatIndex = 0;
$this->SelectedResult = false;
$this->Salt = false;
$this->SaveAs = "";
$this->Statement = "";
$this->Table = "";
Should have done it. Are you sure that is the uploaded version?
PatriceWebAssist
update:
I found a more recent rsobj.php version of 2.40. That solved it.
Question: is there a download of that version available as a stand alone? While I thought I had the most recent, I was using an earlier version in my saved file. Perhaps a place to download it would be helpful when needed. Just a thought.
It is best to reinstall DataBridge periodically, particularly when you run into issues like this that a newer version of a file fixes. If you reinstall you will get the latest version of this file as well as any other bug fixes I've implemented since your last installation.
