Nothing happens when I submit my registration form
Thread begun 3/12/2021 11:41 am by jo271221 | Last modified 3/19/2021 12:22 pm by Ray Borduin | 2841 views | 9 replies |
jo271221
My registration does not submit, I have the registration and log in on the same page, does that create a problem?
I copied code from a working page create account page, into my designed page and my designed page is not working. It does not submit the data to the database. It also gives an error once register is hit (Invalid user name or ... rather than "You have successfully registered, please log in."
I attempted to to inspect element and view debugger and I cannot see any missing assets.
I have the registration and log in on the same page, does that create a problem? I was thinking it was more user friendly to have both on the same page as I see on many other websites.
URL and FTP in private message.
Your Authenticate User server behavior uses the trigger "any form post". That would cause the registration form to trigger the login. I think it will work properly if you update the triggers to use the "Button Press" triggers.
jo271221
Thank You!
I did a find for 'any form post' on the login.php, wavt_validatedform_php.php and authentication.php Where do I find that?
Open the server behavior and change the "Trigger" value.
jo271221
I have attached a screen shot showing that the server behavior gives me two options but there is only one insert. I used the registration button pressed, tested the page and it did not insert. Also my successful log in, failed log in, registration success, registration fail messages are not working now.
Let's do one thing at a time. Do you want to deal with registration or login first? What page should I be looking at? Please provide a url and steps to reproduce including the username and password you are using if you want me to look at login issues.
jo271221
Both the log in and the create account are on the same page as I felt that provided a better user experience.
I believe they are conflicting with each other.
The log in was working until I adjusted the Trigger Value on the server behavior.
So I guess we need to go back and work on the log in page and then the create account/registration once the log in page is working again.
I will be happy to schedule a session since this appears to be complicated.
I am putting the page, log in credentials and FTP in private message.
Thank you!
Let's do a screen sharing session so we can test and work on it together. I'm sure it will be quick and we seem to be missing something trying to do it through the forums.
jo271221
The log in portion is now working. It is just the messages that do not appear once logged in and the registration is not submitting.
The rules are missing from your rules file. Try uploading webassist/security_assist/helpergrouprules.php
