In PHP 7.4, I have MySQLi connections with 3 variables in the query — possible? or replace get_magic_quotes_gpc
Thread begun 3/11/2021 5:02 pm by dionysus224892 | Last modified 3/12/2021 10:47 am by Ray Borduin | 1693 views | 5 replies |
dionysus224892
Hi, the problem is that I have multiple bindParams and when I do more than 1, it screws up.
A. Is there a way to put in multiple as in the following?
SELECT * FROM table WHERE var1 = ?, var2 = ?, var3 = ? AND active = 'yes';
Or if that can't work, then...
B) In the past, I could just use:
if (isset($_GET['seas'])) {
$leyear = (get_magic_quotes_gpc()) ? $_GET['seas'] : addslashes($_GET['seas']);
} else {
$leyear = $currentyear;
And then use the variable in the queries or wherever.
Thanks very much! Nice to see that everything we bought previously still works well!
dionysus224892
The point of this is to do whatever sanitizing/validation is done with a single variable/bindParam.
Using 3 variables causes an error.
I found THIS online :
$calories = 150;
$colour = 'red';
$sth = $dbh->prepare('SELECT name, colour, calories
FROM fruit
WHERE calories < ? AND colour = ?');
$sth->bindParam(1, $calories, PDO::PARAM_INT);
$sth->bindParam(2, $colour, PDO::PARAM_STR, 12);
$sth->execute();
Possible to add order numbers to the existing code?
As in :
$rsShowingsTour->bindParam(1, "i", "".(isset($_GET['id'])?$_GET['id']:"") ."", "-1"); //colname
And then modify the following somehow?
public function bindParam($paramType,$paramValue,$paramDefault="",$paramPosition=false) {
I found this as well :
// A. You can either do one parameter at a time or pass an array to execute().
—$STM->bindParam(":op", "twitter", PDO::PARAM_STR);
—$STM->bindParam(":ou", $user_info->id, PDO::PARAM_INT);
//Or B.
—execute(array(":op"=>"twitter", ":ou"=>$user_info->id));
Thanks!
You can add as many parameters as you need to your recordset. You might consider upgrading to DataBridge v2 in order to create php7 compliant code.
dionysus224892
Hey.. thanks for responding!
I can add more than 1 parameter now as I am currently? or do I need Databridge 2 for that?
Because in the past, when I've put more than 1 parameter, I had errors because it seems that it wasn't sure which ? referred to which variable?
Or does it work by the sequence of the listing of the variables?
BTW, I was planning to upgrade Databridge but the money hasn't been there the past little while...as soon as I'm back to normal, I look forward to it.
You can add as many parameters as you want in previous versions as well. It just won't work on php7 or newer.
dionysus224892
Ahh OK.. that must be when I hit the snag then. Thanks for that. For now, I will remove the deprecated code and either figure it out in the next few days or wait til I'm all updated.
Thanks again for letting me know
