New DWCC help with image bind to databse
Thread begun 3/11/2021 1:43 pm by p_vouers282571 | Last modified 3/12/2021 11:41 am by Ray Borduin | 1180 views | 2 replies |
p_vouers282571
I'm coming from dw CS6 to DWCC and am having a problem picking an image. In CS6 when I do image|insert I get a selection of file or data source. So when I want to use a data source I just select it then add the path to it as path<? recordset stuff that was selected?> kind of like that. In DWCC I do not get the choice of source and for the life of me can figure how to do it. See attached images. Any help would be appreciated.
Add the image with a blank path. Then go to the bindings window and you can bind the src to the recordset.
p_vouers282571
when I bind the image it will remove any path anyway so I still need to go into the code view and add the actual path info to the bound item or it will not find it?? The old cs6 and dw8 let me select the database item, the add the path infront of it, then add it and it was ready to go. I hate change :-)
