DWCC 21.1 Build 15413 - WebAssist Extensions, Server Behaviours, Bindings and Database windows all gone
Thread begun 3/10/2021 2:07 am by Nathon Jones Web Design | Last modified 3/23/2021 10:19 am by Ray Borduin | 2371 views | 5 replies |
Opened DW this morning and the WebAssist menu was missing. Also noticed the Server Behaviours, Bindings and Database Windows were no longer available.
Reinstalled all of the WebAssist extensions, and the deprecated Server Behaviours, Bindings and Database Windows extension from DMXZone and eveything is back in the DW menu bar.
Weird one?
NJ
You shouldn't be installing the deprecated Server Behaviours, Bindings and Database server behavior. Our extensions include updated versions of that, so if you installed that after it could cause some functionality to disappear.
I re-installed the WebAssist extensions and the Server Behaviours, Bindings and Database windows were not available.
It's working now, since I installed the DMXzone version, but I'll keep an eye on it.
Thank you.
NJ
Running into problems now. Can't open recordsets in the Bindings panel. Is the best option to re-install everything BUT the deprecated Server Behaviours, Bindings and Database Windows extension?
I still have to do this via DMXzone, right?
Thank you.
NJ
Oscar (Xavia Digital)
Re
In case it is useful since I had similar problems in the past, I will tell you how we have solved it.
1- Never install the "deprecated server behaviors". Directly install the webasist extensions.
2- Uninstalling dreamweaver and reinstalling it did not help us.
3- Instead what worked was either to create another user account within windows (in case of being a mac I don't know what the solution would be) or to delete all the data from the C:\Users\"YOUR USERNAME"\AppData\Roaming\Adobe\Dreamweaver 2021
This causes dreamweaver to boot as if it were installed again (as new install). You will have to install the extensions after this step and all the sites will be gone. It's the closest thing to a clean install I've come across.
Greetings!
Hello! Thank you Oscar.
I'd forgotten the location of the config file, so thanks for that. Uninstalling the deprecated server behaviours extension and reinstalling the WebAssist extensions appears to have done the trick though.
Appreciate the input.
Regards
NJ
