Ecart 6 will not insert order or order details into db
Thread begun 3/08/2021 9:56 am by Jay Core Global Media | Last modified 3/08/2021 2:06 pm by Ray Borduin | 1631 views | 5 replies |
I have run the wizard and auth.net sandbox is successful however , order is not saved to database
Do you get any errors? Does it go to the success page or failure page?
I can see the data types are set wrong in the store cart summary in database and store cart details in database server behaviors. You can probably just open those server behaviors and update them to use the correct data type for each column.
i do get a succesful transaction details are just not stored. These are the only type of data types i get if you see the sceen shot. Is that the only options am supposed to have?
Yes, just update the columns to text that need to allow text values.
thank you worked perfect. Also have you integrated square payment as of lately? how long does it usually take?
It takes an hour or two at most. I can probably find an old one I did and it would only take an hour.
