Workflow issue.
Thread begun 3/05/2021 8:33 am by Peterson Design Studio - jefferis | Last modified 3/05/2021 10:07 am by Ray Borduin | 1835 views | 5 replies |
Workflow issue.
So, I found 2 issues with the add to cart system. When you enter a product search and click the add to cart button from the results page, and add another item from the same results, instead of adding a new item to the cart, it only adds an additional quantity to the first item selected. In contrast, if you click on the detail pages, and add it to the cart, then the new item is added to the cart. So, to get it right, you have to NOT add any item from the results page and keep clicking on details before adding it to the cart to make it work.
Secondly, when you press the continue shopping item, it goes back to the detail page rather than a new search. Something is wrong with the results page add to cart item, which I think you helped me hand code it.
Update this:
// WA eCart Trigger AddToCart
if (isset($_POST["unstyled"]) || isset($_POST["unstyled_x"])){
$cart $eCart1;
$ATC_itemID "0";
@session_start();
$cart $eCart1;
$ATC_itemID "".($WADAproductAdd->getColumnVal("ProductID"))  ."";
Perfect! What behavior do I modify on completed order to make the confirmation email to the Store Owner go to more than one of the staff? I checked the submit button and don't see the behavior
The "Send Email" server behavior on the confirm.php page can be edited and you can add BCC recipients.
I am not seeing that server behavior on confirm, checkout_success, confirm cart or any other page. ?
The store owner is getting the orders though. Pic is from the confirm page.
Update this line:
//WA Universal Emails
Then it will show... It looks like someone (maybe me) added the 's' at the end. I've seen this when someone tries to save the page with ctrl+s and doesn't realize the s was typed.
