My insert behavior is not inserting
Thread begun 3/03/2021 7:56 pm by NavyChief | Last modified 3/26/2021 7:24 am by Nickmiller | 5070 views | 17 replies |
NavyChief
I created an insert page that does not seem to be inserting. I had to manually alter the code because of conditions I have as a very complicated set of pages.
Please review the attached php page and if you can tell me two things: (1) how come it is not inserting? and (2) can you tell me how to check if insertion took place (I need to set the $isgood value based on if the insertion took place).
You can get rid of this code:
$wa_startindex = 0;
while(!$rsADHOC1->atEnd()) {
$wa_startindex = $rsADHOC1->Index;
$rsADHOC1->moveNext();
$totalRows += 1;
$rsADHOC1->moveFirst(); //return RS to first record
unset($wa_startindex);
and just use:
$rsADHOC1->TotalRows;
It looks like it should insert.
You can check if an insert took place with:
$isgood = ($InsertQuery->InsertID!=0);
NavyChief
That did not work.....
IT still did not insert even with the changes. I made the changes you stated and it still will not insert.
I am baffled.... I read somewhere there is a debug code you can add to see what the SQL response / Errors are... what is it and where should I add that?
It should be:
if ($rsADHOC1->TotalRows == 0) {
NavyChief
Sadly it still will not insert....
does anyone know the debug commands I can add to see what MySQL is returning??
You can usually use die() and var_dump() statements to debug just about anything in php.
If it doesn't work, does it redirect to the rsvp.php page? Are there any errors?
NavyChief
Still will not insert....
I added a bunch of debug commands into the page I am sending and a screen capture of the results.
I'd need to debug this with you in a premier support ticket. It is too complex to just look at and figure out without having my hands in the code.
NavyChief
I prefer to hear from any other people that might have seen this before I pay for a premier ticket for a non professional site (read no budget for premier tickets).
Does anyone else see why this code is not inserting???
Create a simplified page that demonstrates the issue without hand coding and I may be able to help more. Attach the page in your reply..
My guess is that maybe you aren't setting a value of a field that doesn't allow null, so the insert fails?
