form that loads results in an framework plug-in always jump to top of page
Thread begun 3/03/2021 7:13 am by SCar87011738 | Last modified 3/05/2021 8:58 am by Ray Borduin | 1544 views | 5 replies |
SCar87011738
Hello all,
I have a simple form with two fields and a button.
When the user clicks the button, the form should submit and load a plug-in on the same page, without reloading the page.
But everytime I submit the form the page jumps to the top.
There is no redirect since I would like to load results using ajax (plug-in).
Is there a way to load the plug-in without refreshing the page and prevent the page to scroll to top?
TIA
Tony
It shouldn't load to the top. Are you sure it isn't submitting the form as well? I'd have to look at the page.
SCar87011738
Hello ray,
yes, the form is submitting, infact, the plug-in will load when I click the submit button. Practically, the submitted form will load the plug-in that contains a recordset that filters a table based on the form post values.
I tried to add an action to the form (#myform) so that when it submits it will reload the page but at least the page will scroll to #myform.
This is not what I intended to obtain but it almost work...
Tony
That page appears to be password protected, so I can't view it from the browser.
When I open the page via ftp, I don't see any code that loads a plugin with ajax, so maybe it is a different page in a different directory? I don't even see the bricook-new folder.
SCar87011738
Here is the page: brico-ok-card.php
You are already inside the bricook-new directory ;).
Thanks again
tony
Apply the "load plugin to div" Behavior in the onsubmit event of the form. That should prevent the page from refreshing but still post the data and refresh the div.
