Problem initializing File Upload Wizard
Thread begun 2/25/2021 2:04 pm by acornist | Last modified 2/26/2021 12:44 pm by Ray Borduin | 1510 views | 4 replies |
acornistBeta Tester
When launching File Manipulation > upload files, I get this error:
uiinitialize error: RangeError: invalid arra length.
I can edit the behavior on another page, but if I cut and paste the code from the good page to the new page, I still get the error.
I deleted the MacCache file and restarted - no change.
I also reinstalled DataBridge 2 - likewise, no change.
This seems to have happened following an update to the latest Dreamweaver (21.1). I'm running Mac OS Big Sur (11.12.1) on a 2019 MacBook Pro,
It is probably something wrong with the page you are applying it on. If you attached the page I could take a look.
acornistBeta Tester
the page, admin-sku.php, is attached.
You have a form element named "size"
That is a reserved word in html and breaks Dreamweaver pages. If you rename that form element it should fix your issue.
acornistBeta Tester
Thanks, Ray. I can't believe what an idiot I am.
