Insert to two table
Thread begun 2/25/2021 4:35 am by Jonas | Last modified 3/03/2021 2:40 pm by Ray Borduin | 1814 views | 4 replies |
Jonas
Insert to two table
I want to insert products to two different tables (product) and (translate) at the same time.
The product table contains all data.
The translate table contains unique translation fields, and is linked to the product table.
Step 1: Insert to product.
Step 2: Insert to translate. (When writing to this table, I want the id to be retrieved from product.pro_id and filled in translate.tra_proID.)
How do I do this?
Here are the tables:
product
pro_id
pro_name
translate
tra_id
tra_langID
tra_proID
Just apply to insert server behaviors. Don't set a redirect in the first one, so the second one will have a chance to run.
Jonas
But i don't know how to think about how to automatic assign the translate.tra_proID with the result from product.pro_id. Because its on the same page, I don't know how to apply this.
There is an option to save the insert id into the session. Use that and you can refer to it from the session in the second.
Jonas
Thanks Ray!
