Update before page loads
Thread begun 2/23/2021 1:42 am by Sweens | Last modified 2/23/2021 12:55 pm by Ray Borduin | 1817 views | 4 replies |
Sweens
Hi Ray
I have the attached page which creates a URL 'slug' from a newly created page title. It works after submitting the form. However, I'd really like it to update the field before the page submits (one less thing for the user to do) - but this obviously won't work as it is, as the form isn't created before the page loads!
I can move the 'slug' code before the update code - but how do I call it 'something' so that the update behaviour takes the value of 'something' ?
Many thanks
Chris
Just define a variable with the value and then refer to that value in the update like:
$something = "test";
then set the update column value to:
<?php echo($something); ?>
Sweens
Hi Ray
Many thanks. We're at the limit of my knowledge here! Where do I name the 'test' part? echo create_slug("".$rsPg->getColumnVal("pg_slug")."")."";
I move the slug code between the recordset and the update behaviour:
function create_slug($string, $charset = 'utf-8'){
$string = htmlentities($string, ENT_NOQUOTES, $charset, false); // convert accented characters to entities
// strip unwanted parts of entities to leave unaccented character
$string = preg_replace('~&([A-za-z])(?:acute|cedil|caron|circ|grave|orn|ring|slash|th|tilde|uml);~', '\1', $string);
$string = preg_replace('~&([A-za-z]{2})(?:lig);~', '\1', $string);
$string = preg_replace('~&[^;]+;~', '', $string); // remove other entities
return preg_replace('~[\s!*\'();:£@&=+$,/?%#[\]]+~', '-', $string); // replace spaces and illegal characters with hyphens
Cheers
Chris
I'm not sure what you are trying to use to create the slug. This looks wrong.
I think instead of:
it would be something like:
$newSlug = create_slug($_POST["ProductName"]);
Sweens
Hi Ray
It works fine with the form field; it's the code supplied as a Dreamweaver snippet.
UPDATE - I've got it working!
Many, many thanks
Cheers
Chris
return preg_replace('~[\s!*\'();£:@&=+$,/?%#[\]]+~', '-', $string); // replace spaces and illegal characters with hyphens
$newSlug = create_slug("".$rsPg->getColumnVal("pg_slug")."")."";
if ("" === "") {
$UpdateQuery = new WA_MySQLi_Query($connEGM_i);
$UpdateQuery->Action = "update";
$UpdateQuery->Table = "page_content";
$UpdateQuery->bindColumn("pg_url", "s", "".($newSlug) ."", "WA_DEFAULT");
$UpdateQuery->bindColumn("pg_sortorder", "i", "", "WA_DEFAULT");
$UpdateQuery->addFilter("pg_id", "=", "i", "".($_GET['pg_id']) ."");
$UpdateQuery->execute();
$UpdateGoTo = "3-pages-main-pic.php?pg_id=".$rsPg->getColumnVal("pg_id")."";
if (function_exists("rel2abs")) $UpdateGoTo = $UpdateGoTo?rel2abs($UpdateGoTo,dirname(__FILE__)):"";
$UpdateQuery->redirect($UpdateGoTo);
