eCart doubling price
Thread begun 2/22/2021 1:46 pm by Peterson Design Studio - jefferis | Last modified 2/23/2021 3:45 pm by Ray Borduin | 2129 views | 7 replies |
Wow, this is weird, So I was following the tutorial on the product detail page http://www.webassist.com/tutorials/Integrating-Data-Bridge-and-eCart
add to Cart button. And I found a couple of problems. 1. the cart page is doubling the wholesale price in the cart.php 2. the thumbnails are not showing in the cart. I tried adding <td ><img src="images/products/<?php echo $eCart1->DisplayInfo("Thumbnail"); ?> and that worked sometimes and not others.
3 It seems if I use the add to cart button on the results page instead of the detail page, it wipes out the other items in the cart.
Finally, I need to add a default image or show no image if the thumbnail is missing.
I'm going to add a reply, because when creating the first question on a thread, you can't put in private message text.
I'd need FTP access to debug and find any issues in your php code.
thanks ray
The price didn't appear doubled when I tried.
What product did you add? What was the price, what price did you expect?
You had some issues on your login and forgot password pages that I addressed, and I added the usergroup session variable to the login page. Now you can just add the security assist rule to check its value.
The results page doesn't add to the cart or redirect, because you haven't applied the add to cart server behavior on the page.
Hi, when I was adding items, it was showing $1.10 but when i got to the cart it would show $2.20 But since you did the update the product results page is returning a blank page and no php error is displayed. I can't see any items now.
Next time, I will just buy the powerstore for my next clients. Got to be easier than this :-0 I see you are working on product results and detail pages. Thank YOU . However, now the cart.php page is no longer working.
Also, I was going to add the ADD TO CART button to the results page, but if I do , it adds a form within the form which is not allowed. But if I remove the existing form tabs, the magnifying, link to detail page, will no longer work... Any ideas?
It looks like your add to cart is set to use the ProductPrice column not the WholesalePrice... that is why it is doubled.
I fixed your products results page add to cart button and the button on the details page for you so they work properly now.
Thank you Ray!
