You have an error in your SQL syntax
Thread begun 9/19/2009 8:37 pm by james276087 | Last modified 9/25/2009 11:35 am by james276087 | 10657 views | 12 replies |
james276087
Now i have this message for my database:
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '-code='09650', typelicense='a', endors='passanger with air', experance='10 years' at line 1
You might recognized me by name James
Now i am able to Log in and see my Profile page, but after i entered the data i got this message....again Help
thanks for reading this message
James
The error is occurring because you are using a hyphen in your column name "zip-code".
MySLQ sees the hyphen as a Minus sign, so the name "zip-code" is interpreted as "zip minus code"
In naming column in your mySQL database, you should use only alpha numeric characters, the only exception being the Underscore (_). Try renaming the zip-code column to either "zipCode" or "zip_code"
james276087
thank you Jason
james276087
not redirect to Profile page again??
Jason,
I said it " almost there" but need more help....
After change " zip_code" but Log In Page doesn't redirect to Profile Page.
But On Log In page show " array(0) { } ".
After test for session management on my server, don't i have to remove those code???
thanks again,
James
You can remove The following code from the login page that was added:
<pre><?php var_dump($_SESSION); ?></pre>
I am not able to register a new user to test, your registration page is still using the zip-code column.
james276087
How are you? Jason
I did remove the code from Login page.
I didi change the zip code before, copied from database column
zip_code int(10)
thanks
I am trying to register at:
members_Registration.php
the registration page is still using the zip-code column. I get an error when trying to register:
Unknown column 'zip-code' in 'field list'
after changing the column name in the database, you should rebuild the security assist pages.
james276087
Jason,
Do you mean i have start all over again....???
Yes, the security assist code was generated for a column named zip-code, it needs to be regenerated for the column named zip_code.
the easiest way to accomplish this is to recreate your pages using the wizard.
The not so easy way is to go into each server behavior on the pages created and rebind the zip_code column.
james276087
I will
Jason,
OK it is good to practice, i will go over very carefully and remember that my mistakes.
It was very nice to work(?) with you and again thanks for your time and patient.
Wish me Good Luck.....Next time i might post " I DID IT"...
James
