Customer catalog issues
Thread begun 2/14/2021 2:52 pm by Peterson Design Studio - jefferis | Last modified 2/19/2021 12:54 pm by Ray Borduin | 3467 views | 10 replies |
I was finally able to get the customer catalog created, but I am having a few issues. Unless the product name EXACTLY matches the product, like Concrete 40lb bag, it will not show up if you type in Concrete. Also, it created a delete button on the detail page. Not sure why. That shouldn't be in a customer catalog.
Another question is there a way to add more fields to the search page without redoing the entire search catalog? Like description, etc. and make it less exact?
http://66.39.111.101/products_search.php Also, if you type in nothing, and hit search, you get the entire catalog. Well and good, but it is producing a strange string for each page that is being added to the name.
Please attach the .php pages involved so I can take a look and comment on what needs to be changed.
You can manually add new fields to the search page in Dreamweaver and update the Search server behavior on the results page to change how the search works and what fields it recognizes.
Once you run the wizard, you can continue to use Dreamweaver to update the pages however you need to customize them.
I tried double clicking on server behaviors to add additional fields to the search page, but nothing happened. Drag and drop did not work either.
You can add fields to the search page by using the insert text field option in Dreamweaver. HTML elements aren't added through the Server Behaviors. You can add form elements directly through Dremaweaver or copy/paste one of the existing fields and rename them.
The server behavior is on the results page and it is used to add the field to the search once you have added it to the page.
what about these: In Search, unless the product name EXACTLY matches the product, like Concrete 40lb bag, it will not show up if you type in Concrete. Also, it created a delete button on the detail page. Not sure why. That shouldn't be in a customer catalog.
Just delete the delete button from the page and remove the delete server behavior and that should take care of that.
You can use "keyword" search type in the database search server behavior and that would allow you to do partial matches. If you attach the pages you are working on then I could be more specific.
they were attached in the second post
Yes.. you can delete the code on lines 4-15 and remove the delete button from lines 182-185.... you can also remove the overlay popup on lines 204-217.
There is an option to include a delete or not in the wizard, but now that it has run, it is easier and better to just delete it manually.
On the results page you can open the Database Search server behavior and change the "Comparison" from "=" to "includes" and then it won't have to be an exact match.
which = do I replace?
$searchWADAproducts_WADbSearch1->clearSearch();
$searchWADAproducts_WADbSearch1->setSearch(array("type"=>"Edit", "comparison"=>"=", "join"=>"AND"), array("ProductName"), "s", "ProductName");
$searchWADAproducts_WADbSearch1->setSearch(array("type"=>"Edit", "comparison"=>"=", "join"=>"AND"), array("ProductMetaKeywords"), "s", "ProductMetaKeywords");
$searchWADAproducts_WADbSearch1->setSearch(array("type"=>"Edit", "comparison"=>"=", "join"=>"AND"), array("ProductPrice"), "d", "ProductPrice");
THE FIRST or second = in the "comparison "=>"="
Also, on page 2 and following of the results I see this extraneous info:
&pageNum_WADAproducts=1
&pageNum_WADAproducts=14" CORRUGATED TO SandD ADPT 24/CT
you said: The server behavior is on the results page and it is used to add the field to the search once you have added it to the page.
I found that in the basic search Since I or the wizard did not add all the other fields to the query, adding description, eg., is not available in the server behaviors connection. It looks like I have to redo it from scratch to add more fields.
