Uncaught error search
Thread begun 2/11/2021 3:22 pm by Peterson Design Studio - jefferis | Last modified 2/22/2021 8:36 am by Ray Borduin | 1413 views | 4 replies |
Hi Ray, I have created a product catalog and search /results, but I'm getting an error and want to make sure it isn't a setup in the server connections:
Fatal error: Uncaught Error: Call to undefined function virtual() in /usr/home/ds/public_html/ds.com/products_results.php:3 Stack trace: #0 {main} thrown in /usr/home/ds/public_html/ds.com/products_results.php on line 3
http://66.39.111.101/products_search.php running the site as an IP as the url is not live.
virtual() is an Apache-specific function, Dreamweaver uses it instead of require_once() when your site definition is set to use absolute paths instead of file relative paths.
so should i replace virtual with require once or just add a forward slash before Connections like this: <?php virtual('/Connections/DealersSupplyCo.php'); ?>
Whichever you want to use as long as you are on apache. I usually use file relative paths and require_once() but I don't think it matters that much.
FYI. If I leave the forward slash in the call <?php require_once('/Connections... it doesn't work. It has to be relative... this may create a problem for admin inside a sub-directory I think
