How can I put a placeholder on CKeditor
Thread begun 2/08/2021 1:44 pm by lr_leal239405 | Last modified 2/08/2021 4:11 pm by Ray Borduin | 2598 views | 5 replies |
lr_leal239405
Is there an easy way to add a placeholder in the CKeditor box?
I tried.
$CKEditor_config["editorplaceholder"] = "test";
Of course, it doesn't work. Thank you.
I just tested and that syntax worked for me. Are you using the latest version?
lr_leal239405
I think I have 4. How do I check version again?
/webassist/ckeditor/ckeditor.js
Search for "version:"
lr_leal239405
version:"4.9.2",revision:"95e5d83"
If you install the latest version of databridge it includes v 4.15.1 and it works in that version. You could also try adding the plugin: https://ckeditor.com/docs/ckeditor4/latest/features/editorplaceholder.html
