insert not working
Thread begun 2/07/2021 4:56 am by Sweens | Last modified 2/07/2021 1:15 pm by Ray Borduin | 972 views | 2 replies |
Sweens
insert not working
Hi Ray
The attached page has quite a bit going on on it - whether this is causing a conflict, I don't know - but I have 2 insert behaviours on the page and neither works. I've tried with a form action of the page name and without.
I've compared it with other pages with a working insert behaviour on, and can't see any difference.
Cheers
Chris
It is probably failing the validation which runs any time a form submits. Try changing the Server Validations trigger to only run on the button press associated with the attachments you are validating.
Sweens
Thanks Ray - that nailed it!
Cheers]
Chris
