shipping displayed added custom add cart question
Thread begun 2/01/2021 1:58 pm by lr_leal239405 | Last modified 2/03/2021 2:04 pm by Ray Borduin | 1637 views | 4 replies |
lr_leal239405
I have a (eCart) page in which the checkout does not calculate add the shipping line when pressing 'Shipping Same as Billing' even though I can see on a var_dump that a it successfully communicates with UPS and has a value. The page is custom made where I copied the server behaviors needed to go thru same checkout as the eCart. Everything has been working but the shipping is not added. I can give you all the info if you need it but maybe you can tell me what I could be missing so I can find it. (from line number 198 to 234 (the Add to Cart function)).
Attached is the file. It goes to the same cart.php and checkout files. What could I be missing?
There is too much custom code for me to dig through and find the issue. I'd have to debug this with you in a premier support screen sharing session in order to track it down.
lr_leal239405
Ok, I'll try calling you this week before Friday. Thank you.
lr_leal239405
Can I call you now regarding this shipping charge issue?
Yes. I'm available now.
