load plugin to div while users scroll down the page ?
Thread begun 1/28/2021 2:19 pm by Jose | Last modified 1/29/2021 8:46 am by Ray Borduin | 1492 views | 5 replies |
Jose
Hi there, I'm trying to load all products in the front page on scroll down using ajax with Framework Builder like the one you have in http://www.webassist.com/tutorials but I don't know how to get it done. Any idea ? how it is possible using this plugin ?
It takes a little custom coding.
First, you have to create a plugin from the results portion of the page that you want repeated. Then use the Behavior "load plugin to div", which has an option to append content instead of replace that you have to manually update.
Then you need to put something below it like an image that you can detect when it is on the page using javascript. Then whenever the thing below the content is visible, you know to load new content with the load plugin to div server behavior.
The final trick is to keep the count of the page loaded and increment it when a new page is added to the bottom, so you can keep track of which page to load next and pass that in when you load it.
This is something I could help with in a premier support ticket.
Jose
thanks Ray
Contact me via skype to schedule... I can probably work in it with you tomorrow.
Jose
Ok
my skype name is: webassist.rborduin
