Im having a problem trying to get images to show on results, Details pages
Thread begun 1/28/2021 12:53 pm by willo009412397 | Last modified 2/04/2021 7:57 am by Ray Borduin | 1922 views | 6 replies |
willo009412397
I have used Dataassist in the past, and have upgraded to Databridge (Well done, by the way, the power Databridge enables you to have is amazing), however, I know it will just be something small I am missing. As with Dataassist, we click on the image tag on the page, edit > insert image > Data source, and pick the corresponding value within the page Recordset. But in Databridge the uploaded image is taken care of for us, but when trying to go through the steps above, when I click to expand the recordset, it was its encountered a problem? I wanted to know if this is right and has something to do with using SQLI rather than SQL? or if there is something I am missing?
No, that should work. Does it work to create a recordset? Have you tried clearing your server scripts?
willo009412397
Ok I have tried a few things but nothing seems to have worked, I have uploaded some files for you to look at. Maby replicate at your end, I have also added a txt file that shows an image of the error I get and a list o things I have tried so far. Thanks for your help.
I think your testing server settings in dreamweaver is the issue. You didn't answer my question. Can you create a recordset or test the connection? What error do you get. Most of the time database connection issues are bad testing server settings, usually either no testing server configured, or a bad testing server url.
willo009412397
When I create the connection file, I test it it says a Connection is made. In the Database Panel within Dreamweaver, I can see my Database and its Tables. I try to add an Image to the Results page using Image from Data Sources and then it says "An unidentified error has occurred. ". If I create another Recordset to the page it says the same. This is what I cannot understand? I have a connection
I'll have to debug this with you in a screen sharing session. Please reply with a US phone number or Skype contact information in the private area and I'll give you a call to set it up.
willo009412397
Thanks, Ray for your help, I have managed to solve the issue. It seems to have been an Issue with the XAMPP installation I was using, even though it was the latest version, for some reason it was putting out the error I encountered. Quick fix, installed a later version o XAMPP and the same settings work great. Thanks for your speedy replies to my problem. I'm sure I will be back haha.
