Form Persist Behaviour
Thread begun 1/28/2021 6:02 am by s.joiner74419001 | Last modified 2/03/2021 10:11 am by Ray Borduin | 1492 views | 4 replies |
s.joiner74419001
I am having trouble getting the Persist Form Behaviour to work.
I have an estimate form on my home page ( index.php ) The forms action is quote-result.php which has a form that I want to display the data from the previous form so it can be checked before submission to the database.
I have added the persist form behaviour to the index.php page and added the persist form bindings to the form on the quote-result.php page but it does not display the data.
I've attached the two pages.
Any Ideas?
Thanks in advance.
Your form submits directly to the quote-result.php page. The persist form code has to run on the action page of the form it is storing.
s.joiner74419001
Ok so i guess Form Persist isn't what I need for the function I want to achieve.
So i've adjusted this and removed Form Persist, then changed the form method to GET. then I bind each URL parameter to its corresponding form field on the quote-result.php page.
This I think will work fine but i'm having trouble binding the checkbox array ( status[] ) so the correct checkboxes are selected.
How can I achieve this.
Ive attached updated files.
Thanks in advance.
<input type="checkbox" name="status[]" value="1" <?php echo((isset($_GET["status"]) && in_array("1",$_GET["status"]))?"checked":""); ?>>
s.joiner74419001
Just the job!! thanks Ray!
