unable to define database connection
Thread begun 1/25/2021 8:32 am by software.current355386 | Last modified 2/22/2021 9:04 pm by Telstra Support | 4228 views | 14 replies |
I AM STUGGLING TO DEFINE A WORKABLE DATABASE CONNECTION CAN ANYONE ASSIST
THE SITE CONSISTS OF A CONNECTIONS DIRECTORY AND IMPORTED DATABASE
NO TABLES Are found
Dreamweaver uses your testing server to connect to the database. If you go to the database connection page and click test for your connection what happens?
Is your local server running? Can you connect via phpMyAdmin to the local database? Since this is an issue on your testing server, I'd need to do screen sharing to debug it. If you post your phone number or skype contact information in the private area of a reply, then I can call you and help you figure it out in a quick screen sharing session.
local running can access via sdequal,pro
no tables found
We found that the localhost web server wasn't running properly in a screen sharing session. If you can't browse the url listed as the testing server url in dreamweaver, then dreamweaver won't be able to connect to your database. Maybe look at any error files in your MAMP server or try reinstalling MAMP to resolve the problem. Once you can browse your localhost, I think you will also be able to view the database in dreamweaver.
access via sequel pro and phpmyadmin. but still not by site
any thoughts
It has to be the testing server settings not pointing to the correct url.
TRACKED PROBLEM DOWN FINALLY.
DID A COMPLETE REINSTALL OF MAMP PRO , UNDERSTOOD THE DEFAULT PASSWORD FOR ROOT TO BE ROOT AND HAD BEEN WORKING ON THAT PREMISE, SO I DECIDED TO CHANGE ROUTES PASSWORD ... AND IT WORKED.
SO CHANGED ROOT PASSWORD TO ROOT AND IT WORKED AGAIN, THIS TIME I DELETED THE PASSWORD AND THE PROBLEM RE-APPEARED
HAVE TRIED IT OUT AN IT WORKS FINE,.
JUST SHOWS THAT IT DOESNT PAY TO ASSUME DEFAULTS ARE NOT ALWAYS IN PLACE
I'll contact you via skype to set up a screen sharing session.
c pm
You are in php7 and powercms has not been updated to php7 in the extension. You can download and replace the files manually with the php7 version here:
https://www.webassist.com/PowerCMS.zip
