multiple updates
Thread begun 1/23/2021 9:47 am by Sweens | Last modified 1/25/2021 10:11 am by Ray Borduin | 1028 views | 2 replies |
Sweens
multiple updates
Hi Ray
I've tried the repeat server behaviour and the Repeat Selection (improved) method as the basis for updating multiple records and neither will work (I've done each about 5 times!).
I've referred to other pages that have the multiple update on them and I can't see anything different. - Hope you can spot what is probably blindingly obvious to you!
Cheers
Chris
I think the issue is that you don't have the off_id in the rsMGposts recordset. You need to add that column to the recordset so it can keep track of which record you are updating.
Sweens
Thanks Ray - that did it.
Cheers
Chris
