How to create menu editor
Thread begun 1/21/2021 4:18 am by Raza | Last modified 1/29/2021 8:50 am by Ray Borduin | 2667 views | 9 replies |
Raza
hi,
can you guide me how to create Menu Editor like Wordpress using MySQLi Server Behavior please provide me any code or tutorial? I am attaching an example
regard
You would add a column in your table to store the sort order, then use something like: https://jqueryui.com/sortable/ to create the drag/sort behavior and submit the changes.
Then you could use MySQLi server behaviors to do the update in the table.
There is no tutorial on this, but it is something I could help with in a premier support ticket.
Raza
hi sir,
Thanks for reply, sorry I cant afford your premiere support. if you can provide any tutorial or code idea its better otherwise I will search it again.
regard
Look through the jquery sortable documentation and it should all be there.
Raza
but how to add MySQLi server behaviors to do the update in the table?
You can get the sortable function to submit an array of ids in the correct order. Then you write a loop that goes through the array and wrap that around the update server behavior to update the id's and set the appropriate order.
Raza
hi Ray,
hope you fine, I have found a tutorial code I hope it will works successfully :)
Raza
hi Ray,
can we update data with data-position attribute?
I'm not sure what you mean? Data has to be updated through a form submit. If you add that attribute to a form submit, then it can be used to update data in the database.
Raza
hi,
Thanks for Response. I would like to inform you that I have found tutorial & also script during searching.sorry for waste your valuable time.
Thanks Again
