Adding one search field to existing DataAssist results page
Thread begun 1/19/2021 12:08 pm by tmcbinc99963 | Last modified 1/19/2021 3:01 pm by Ray Borduin | 2597 views | 8 replies |
tmcbinc99963
I would like to add a single search field to an existing DA results page that was set up with WA plugins.
I added the search, but can't seem to get them both to show results. Can they both use the same DA created recordset and Search server behaviors?
The search field created with DA works fine, but the single search I added has never worked and shows all results. Have tried multiple iterations of text field names, wizard settings, etc. with no change.
The site isn't live yet, so hopefully you'll be able to see the problem by viewing the page. If not, I can throw it up on our server.
Your text field name is the same as your button name. The name of your form elements need to be unique for each form.
What column are you trying to search against with this field? I don't see the text field name in the search server behavior either.
tmcbinc99963
I'm looking to search the whole database with a single text field search.
All columns? You would need to update your database search server behavior and add a keyword search and select all of the columns.
tmcbinc99963
I changed the name of one of the forms, and included a keyword search for all columns. Same problem.
Should a value be set for the keyword in the wizard? If so, should the value be taken from the form, session, or form name?
The URL for each search is included in the PM. Are these supposed to be different?
Please attach the updated page.
You still didn't update your form element name. You have:
html:
<input type="text" name="Search" class="form-control mr-sm-2" placeholder="Search" aria-label="Search">
<span class="buttonFieldGroup" >
<input type="submit" value="Search" class="formButton unstyled" id="Search" name="Search" />
</span>
it should be:
html:
<input type="text" name="Keyword" class="form-control mr-sm-2" placeholder="Search" aria-label="Search">
</span>
You also didn't bind the keyword search in your Database Search server behavior to a form value.
Update the keyword search and click the lightning bolt to select the newly renamed "Keyword" field to search against.
tmcbinc99963
Updated page.
I don't see any of the updates I suggested in the latest zip.
The form element is still named search and the keyword search in the database search server behavior still doesn't have a value set.
