just upgraded V2 DataAssist because was error While executing timer Wa_SiteTools_Progress_V2 htm, following Javascript error occured: Line 867 file C\users\garyheide\appdata\roaming\adobe\dreamweavercs6\en_us\configuration\floaters\WA_sitetools_progr
Thread begun 1/19/2021 8:08 am by rebuilt157571 | Last modified 1/19/2021 12:36 pm by Ray Borduin | 1916 views | 4 replies |
rebuilt157571
just upgraded V2 DataAssist because was error While executing timer Wa_SiteTools_Progress_V2 htm, following Javascript error occured: Line 867 file C\users\garyheide\appdata\roaming\adobe\dreamweavercs6\en_us\configuration\floaters\WA_sitetools_progressV2
I just upgraded to V2 of DataAssist because I was getting the error "While executing timer in Wa_SiteTools_Progress_V2.htm, the following Javascript error occured: At Line 867 of the file C\users\garyheide\appdata\roaming\adobe\dreamweavercs6\en_us\configuration\floaters\WA_sitetools_progressV2.js:wa.dataassist_settings.pages.update_page has no properties
The new version V2 did not help with this error.
Using Dreamweaver CS6, had a clean php page and trying to create a Results and insert page.
I'll need to debug this in a screen sharing session. Please post a phone number and good time to reach you and we can look into it together and get it fixed.
rebuilt157571
Hi Ray.
rebuilt157571
Me again, Closed out dreamweaver and restarted when I try to open Data assist, I get the message " While executing onload in WA_Main.htm, the following javascript error occured: "in the file "WADA_Main:" initializeUI is not defined Data Assist pages will not run at all.
Clear your winfilecache.dat file... I think that will solve it.
