PowerCMS2 adding stray numbers when inserting data?
Thread begun 1/17/2021 11:52 pm by cldsk | Last modified 1/18/2021 2:24 pm by Ray Borduin | 1913 views | 5 replies |
cldsk
PowerCMS2 adding stray "1" when inserting data?
I am using the latest version of PowerCMS2 on a site - when I insert a content area in the site - the content appears, but in this case a "1" precedes the content. This isn't in any of my code, so I am not sure where it is coming from? Will post in private message link, but it is in both the content area (above the heading text) and the meta-title, and at the top of the website (meta-description/keywords).
Many thanks for any help!
cldsk
update with private message
On your page you have:
<?php echo(require_once("/home/everlandministry/public_html/WA_CMS/WA_CMS.php")); ?>
it should just be:
<?php require_once("/home/everlandministry/public_html/WA_CMS/WA_CMS.php"); ?>
cldsk
Thanks so much - will remove the stray "echo", though it does appear in the developer's notes. Is there a way to remove that?
You can replace the attached file:
/admin_cms/pages.php
cldsk
thanks so much! Will do!
