forgotten password always says 'invalid information' even though it isn't!
Thread begun 1/15/2021 12:59 pm by Sweens | Last modified 3/04/2021 3:37 pm by Ray Borduin | 3519 views | 11 replies |
Sweens
Hi Ray
Driving me crazy, this! I've copied the pages from another site (that works fine), renamed the connection and whenever I try to run the forgotten password routine, it fails.
Can you spot anything obvious?
Chris
I see you are using a keyed encryption... is it possible the users were stored with a different encryption type or the key file has been updated?
Sweens
I didn't know that! Where would I find it?
I also tried rebuilding it from scratch using the wizard, but got the same problem.
Cheers
Chris
Are you using the same registration page as forgot password and login? Is login working?
Sweens
Hi Ray
Yes, login is OK
Cheers
Chris
Can you send FTP access and a URL? I'll have to compare to see if they are all using the same encryption. I'll need to try registering and logging in and the forgot password and see why they aren't all working together.
Sweens
Thanks Ray
pm
It wasn't saving the session variable with the security question answer properly. It may have something to do with your php version or session settings... I couldn't really figure it out.
However, I was able to fix it. I re-arranged the code so the session variable is stored at the top of the page and that seems to have fixed it.
You will have to download the updated versions of the two pages:
webassist/captcha/wavt_captchasecurityquestion.php
webassist/security_assist/helper_php.php
Sweens
Hi Ray
Many, many thanks.
Cheers
Chris
see pm
Sweens
Hi Ray
Unfortunately, this is happening again - and I don't think I've overwritten the files.
Cheers
Chris
