Ecart 5 deprecated warnings
Thread begun 1/15/2021 9:53 am by davehampton | Last modified 1/15/2021 12:49 pm by Ray Borduin | 1516 views | 3 replies |
davehampton
Is my Ecart 5.07 still viable or do I need to upgrade to the latest version. My customer's store is down and here are the warnings:
Deprecated: Methods with the same name as their class will not be constructors in a future version of PHP; eCart1_Definition has a deprecated constructor in /home/onf25u47vjro/public_html/prostuffcleaner.com/WA_eCart/eCart1_PHP.php on line 3
Deprecated: Methods with the same name as their class will not be constructors in a future version of PHP; eCart1_ItemDefinition has a deprecated constructor in /home/onf25u47vjro/public_html/prostuffcleaner.com/WA_eCart/eCart1_PHP.php on line 275
Deprecated: Methods with the same name as their class will not be constructors in a future version of PHP; WA_eCart_Rule has a deprecated constructor in /home/onf25u47vjro/public_html/prostuffcleaner.com/WA_eCart/WA_eCart_Definition_PHP.php on line 3
Deprecated: Methods with the same name as their class will not be constructors in a future version of PHP; WA_eCartDefinition has a deprecated constructor in /home/onf25u47vjro/public_html/prostuffcleaner.com/WA_eCart/WA_eCart_Definition_PHP.php on line 18
Deprecated: Methods with the same name as their class will not be constructors in a future version of PHP; WA_eCartDisplayCSSLooper has a deprecated constructor in /home/onf25u47vjro/public_html/prostuffcleaner.com/WA_eCart/WA_eCart_Definition_PHP.php on line 921
Fatal error: Uncaught Error: Call to undefined function mysql_pconnect() in /home/onf25u47vjro/public_html/prostuffcleaner.com/Connections/proconn.php:9 Stack trace: #0 /home/onf25u47vjro/public_html/prostuffcleaner.com/store.php(9): require_once() #1 {main} thrown in /home/onf25u47vjro/public_html/prostuffcleaner.com/Connections/proconn.php on line 9
You can see if your server can downgrade to php6 or below.
If you need to run php7, then you need to upgrade eCart to v6 for mySQLi support.
davehampton
Another deprecated warning
Hi Ray,
Thanks for the reply. I downgraded the PHP on the server and the store is now working. However, there is text at the top of the page over the page artwork that reads: Deprecated: mysql_pconnect(): The mysql extension is deprecated and will be removed in the future: use mysqli or PDO instead in /home/onf25u47vjro/public_html/prostuffcleaner.com/Connections/proconn.php on line 9
Here is line 9:
$proconn = mysql_pconnect($hostname_proconn, $username_proconn, $password_proconn) or trigger_error(mysql_error(),E_USER_ERROR);
You can just turn off deprecated messages in your php.ini file, or in the code before that error:
ini_set
("display_errors",0);
