message error when inserting
Thread begun 9/19/2009 8:46 am by brunodarwin371999 | Last modified 9/24/2009 9:11 am by brunodarwin371999 | 4806 views | 8 replies |
brunodarwin371999
I am working on localhost.
I have created a very simple database with PHPmyAdmin.
Just one very simple table : "visitors" with 2 fields :
"ID" and "NAME".
In PHPmyAdmin, I can add names and see them in Dreamweaver.
However, when I use DATA ASSIST V2, I cannot INSERT DELETE or UPDATE any new name.
For example, I get the following error message in my browser when I try to INSERT a new name :
Notice: Undefined offset: 1 in C:\wamp\www\dbdb\WA_DataAssist\WA_AppBuilder_PHP.php on line 125
Notice: Undefined offset: 2 in C:\wamp\www\dbdb\WA_DataAssist\WA_AppBuilder_PHP.php on line 126
Unknown column 'undefinedfundefined' in 'field list'
Here are the line codes to help :
123 $WA_typesArray = explode(",", $columnTypeList[$i]);
124 $delim = ($WA_typesArray[0] != "none") ? $WA_typesArray[0] : "";
125 $altVal = ($WA_typesArray[1] != "none") ? $WA_typesArray[1] : "";
126 $emptyVal = ($WA_typesArray[2] != "none") ? $WA_typesArray[2] : "";
if ($formVal == "" || $formVal == "undefined")
I there someone to help me ?
Thank you in advance for your help.
Bruno
brunodarwin371999
In order to help
This post has been deleted.
Can you send a copy of your insert page in a zip archive.
brunodarwin371999
Here it is
Here is the visitor Insert PHP page.
(Very light page)
It looks like the data type was not properly set.
double click the insert Record Server behavior. On the Second page of the wizard, make sure a data type is selected for both columns, then press OK.
brunodarwin371999
Excellent Jason !
In fact, the DA provides a numeric data type instead of text.
(I attached a picture so that you can see it)
> that generates the same problem with update page. But everything is normal when I manually make the correction.
Does the problem comes from DA or from my side ?
Here is also a copy of my small sql file :
CREATE TABLE IF NOT EXISTS `visitors` (
`id` smallint(6) NOT NULL AUTO_INCREMENT,
`Name` text NOT NULL,
PRIMARY KEY (`id`)
) ENGINE=MyISAM DEFAULT CHARSET=latin1 AUTO_INCREMENT=1 ;
Thank you again!
I think it is the smallint data type, the wizard will try to set the datatype automatically, but I think it is getting confused on the smallint column you are using.
brunodarwin371999
Ok Thank you Jason.
To finish how to fix it?
> TINYINT, INT or BIG INT has the same result.
Manually each time ?
Yes, you'll have to fix it manually, it seams DataAssist is not able to retrieve column types from your table for some reason.
brunodarwin371999
Thank you Jason
