The pre-build registration page shows a SQL syntax error
Thread begun 1/06/2021 6:33 pm by Rokon | Last modified 1/08/2021 8:12 am by Ray Borduin | 1455 views | 3 replies |
Rokon
Hello
I was trying to build a user registration system through the wizard and after creating the page I found that when I try to register then a SQL syntax error is coming and note that I didn't modify anything on the per-build pages.
Also on the registration page one extra security question field after the captcha is coming which I need to remove but on the wizard didn't find any option to remove it.
Please help me to solve the problems. I am providing you the ftp info in PM
It looks like your live database is out of sync with the local. It is missing the UserFullName column.
I updated your queryobj.php file to turn on debug mode so it gives the full error on the page.
Rokon
Got it and corrected in live server, now the registration is working fine. Thanks a lot.
Meanwhile also on the registration page extra security question field below the captcha is coming which I need to remove but on the wizard didn't find any option to remove it. Pls help me to get the way to remove it.
Just delete it from the page manually and remove the line in the Server Validations that refers to the form element.
