Ecart6 - Same As Billing to Shipping
Thread begun 12/31/2020 12:31 pm by MAURIANS | Last modified 12/31/2020 2:14 pm by Ray Borduin | 896 views | 2 replies |
MAURIANS
Checkout page is created for paypal payment options only.
I searched forums for "SAME AS" feature to customize Checkout pages but not seeing anything for Ecart... would like to have this auto fill inputs when checkbox is checked via login SESSION binded to RECORDSET to populate.
I already have SESSION & RECORDSET created on page but not able to get SAME AS to work.
The eCart should create a script file: WA_SameAs.js
That file has a function:
setSame(check, tofieldset, fromfieldset)
It depends on the tofieldset form element ID values to match the fromfieldset with "_2" appended.
An example would be:
html:
<form>
<fieldset id="shipping">
<input id="first">
</fieldset>
<div>
<label>billing same as shipping <input type="checkbox" id="same" onclick="setSame(this, 'billing', 'shipping')"></label>
</div>
<fieldset id="billing">
<input id="first_2">
</fieldset>
</form>
<script>
function wa_fireEvent(element,event){
if (document.createEventObject){
// dispatch for IE
var evt = document.createEventObject();
return element.fireEvent('on'+event,evt)
else{
// dispatch for firefox + others
var evt = document.createEvent("HTMLEvents");
evt.initEvent(event, true, true ); // event type,bubbling,cancelable
return !element.dispatchEvent(evt);
function findIndexFromID(id, fromfieldset) {
var theSourceFieldset = document.getElementById(fromfieldset);
var theSourceInputs = theSourceFieldset.getElementsByTagName("select");
for (var y=0; y<theSourceInputs.length; y++) {
if (stripEnum(theSourceInputs[y].id,fromfieldset) == id) {
return theSourceInputs[y].selectedIndex;
return 0;
function findFieldValueFromID(id, fromfieldset) {
var theSourceInputs = theSourceFieldset.getElementsByTagName("input");
if (theSourceInputs[y].id == id) {
return theSourceInputs[y].value;
return false;
function stripEnum(theID,theStart) {
var retID = theID;
if (theID.indexOf(theStart)==0) {
retID = retID.substring(theStart.length);
if (retID.search(/_\d*$/)>0) {
retID = retID.substring(0,retID.lastIndexOf("_"));
return retID;
function setSame(check, tofieldset, fromfieldset) {
if (check.checked) {
var theDestinationFieldset = document.getElementById(tofieldset);
var theDestinationInputs = theDestinationFieldset.getElementsByTagName("input");
var theDestinationSelects = theDestinationFieldset.getElementsByTagName("select");
for (var x=0; x<theDestinationSelects.length; x++) {
theDestinationSelects[x].selectedIndex = findIndexFromID(stripEnum(theDestinationSelects[x].id,tofieldset), fromfieldset);
if (window.CountryChange && theDestinationSelects[x].id == "Country_2") CountryChange("_2");
wa_fireEvent(theDestinationSelects[x],"change");
for (var x=0; x<theDestinationInputs.length; x++) {
if (theDestinationInputs[x].type == "text") {
theDestinationInputs[x].value = findFieldValueFromID(stripEnum(theDestinationInputs[x].id,tofieldset), fromfieldset);
wa_fireEvent(theDestinationInputs[x],"blur");
</script>
If you find the WA_SameAs.js file, then you don't need to include the <script> tag in the above example... all of those functions are defined in that file.
MAURIANS
Thanks I will check file...
